Ana içeriğe geç
PlayStation Move Trigger Button Replacement
Neye ihtiyacın var
  1. PlayStation Move Trigger Button Replacement, Battery: adım 1, 3 resimden 1. PlayStation Move Trigger Button Replacement, Battery: adım 1, 3 resimden 2. PlayStation Move Trigger Button Replacement, Battery: adım 1, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move Trigger Button Replacement: adım 2, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move Trigger Button Replacement: adım 3, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 3, 2 resimden 2.
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
    Peter Miller - Yanıt
  4. PlayStation Move Trigger Button Replacement: adım 4, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 4, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 4, 3 resimden 3.
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move Trigger Button Replacement: adım 5, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 5, 2 resimden 2.
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move Trigger Button Replacement: adım 6, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 6, 2 resimden 2.
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move Trigger Button Replacement: adım 7, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 7, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 7, 3 resimden 3.
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move Trigger Button Replacement: adım 8, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 8, 2 resimden 2.
    • Gently pull on the white piece connecting the battery and the connector.
  9. PlayStation Move Trigger Button Replacement, Motherboard: adım 9, 3 resimden 1. PlayStation Move Trigger Button Replacement, Motherboard: adım 9, 3 resimden 2. PlayStation Move Trigger Button Replacement, Motherboard: adım 9, 3 resimden 3.
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. PlayStation Move Trigger Button Replacement: adım 10, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 10, 2 resimden 2.
    • Remove the two 1.2mm Phillips #1 screws.
  11. PlayStation Move Trigger Button Replacement: adım 11, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 11, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 11, 3 resimden 3.
    • Cautiously remove the circular white piece at the top without removing the LED inside.
    Accidentally ripped this off as my PS Move is a different model, any chance this could be fixed using like jumper wires or not?
    Alex Flint - Yanıt
  12. PlayStation Move Trigger Button Replacement: adım 12, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 12, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 12, 3 resimden 3.
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. PlayStation Move Trigger Button Replacement: adım 13, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 13, 2 resimden 2.
    • Remove the trigger button from the controller.
  14. PlayStation Move Trigger Button Replacement: adım 14, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 14, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 14, 3 resimden 3.
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
    This step is destructive and simply breaks the LED solder joints!!!
    WTF, you literally broke the soldered ribbon cable.
    fastasleep - Yanıt
  15. PlayStation Move Trigger Button Replacement: adım 15, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 15, 2 resimden 2.
    • Remove the motherboard from the plastic case.
Sonuç
Abdulaziz Refaei
162 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 23
Her zaman: 2,818
