Ana içeriğe geç
Sony PSone Laser Assembly Replacement
Neye ihtiyacın var
  1. Sony PSone Laser Assembly Replacement, Upper Case: adım 1, 1 resimden 1.
    • Remove all cables plugged into the PlayStation.
  2. Sony PSone Laser Assembly Replacement: adım 2, 2 resimden 1. Sony PSone Laser Assembly Replacement: adım 2, 2 resimden 2.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Sony PSone Laser Assembly Replacement: adım 3, 1 resimden 1.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. Sony PSone Laser Assembly Replacement: adım 4, 2 resimden 1. Sony PSone Laser Assembly Replacement: adım 4, 2 resimden 2.
    • Lift up and remove the upper case.
  5. Sony PSone Laser Assembly Replacement, Laser Assembly: adım 5, 3 resimden 1. Sony PSone Laser Assembly Replacement, Laser Assembly: adım 5, 3 resimden 2. Sony PSone Laser Assembly Replacement, Laser Assembly: adım 5, 3 resimden 3.
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Marjorie
2.273 İtibar
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 45
Her zaman: 5,991
