Ana içeriğe geç
PlayStation One Lower Case Replacement
Neye ihtiyacın var
  1. PlayStation One Lower Case Replacement, Upper Case: adım 1, 1 resimden 1.
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Lower Case Replacement: adım 2, 2 resimden 1. PlayStation One Lower Case Replacement: adım 2, 2 resimden 2.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Lower Case Replacement: adım 3, 1 resimden 1.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Lower Case Replacement: adım 4, 2 resimden 1. PlayStation One Lower Case Replacement: adım 4, 2 resimden 2.
    • Lift up and remove the upper case.
  5. PlayStation One Lower Case Replacement, Laser Assembly: adım 5, 3 resimden 1. PlayStation One Lower Case Replacement, Laser Assembly: adım 5, 3 resimden 2. PlayStation One Lower Case Replacement, Laser Assembly: adım 5, 3 resimden 3.
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Lower Case Replacement, Mother Board: adım 6, 2 resimden 1. PlayStation One Lower Case Replacement, Mother Board: adım 6, 2 resimden 2.
    • remove the metal plate
  7. PlayStation One Lower Case Replacement: adım 7, 3 resimden 1. PlayStation One Lower Case Replacement: adım 7, 3 resimden 2. PlayStation One Lower Case Replacement: adım 7, 3 resimden 3.
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  8. PlayStation One Lower Case Replacement, Lower Case: adım 8, 2 resimden 1. PlayStation One Lower Case Replacement, Lower Case: adım 8, 2 resimden 2.
    • Remove the metal case.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Marjorie
2.273 İtibar
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 4,524
