Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This will guide you through the process of replacing your PlayStation's optical drive.
Neye ihtiyacın var
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
Carefully disconnect the gold-colored ribbon cable from it's connector.
46 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
What about model SCPH-5501?
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
