Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your PlayStation won’t power on, the power supply may need to be replaced. This guide will take you through the process of replacing the power supply.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
Parçalar
Hiçbir parça belirtilmedi.
  1. Before you begin, make sure the console is turned off and unplugged.
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - Yanıt
  2. While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it. While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. Pull the power supply cable straight up and out of its socket on the power supply to disconnect it. Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
    • Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
  4. Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
    • Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
  5. Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply. Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply.
    • Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
9.553 İtibar
48 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
129 Üyeler
12.549 adet Kılavuz yazıldı
4 Yorum
Since working with the power supply, it's wise to state in writing to disconnect the AC cord, in addition to showing it disconnected as you have.
Collin - Yanıt
Once I take out my power supply how do I fix the issue with the power supply
Tiago - Yanıt
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
kendofox - Yanıt
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 114
Her zaman: 20,598
