Ana içeriğe geç
PlayStation Start and Select Buttons Replacement
Neye ihtiyacın var
  1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: adım 1, 1 resimden 1.
    • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
  2. PlayStation Start and Select Buttons Replacement: adım 2, 3 resimden 1. PlayStation Start and Select Buttons Replacement: adım 2, 3 resimden 2. PlayStation Start and Select Buttons Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
  3. PlayStation Start and Select Buttons Replacement: adım 3, 3 resimden 1. PlayStation Start and Select Buttons Replacement: adım 3, 3 resimden 2. PlayStation Start and Select Buttons Replacement: adım 3, 3 resimden 3.
    • Gently push the rear cover towards the front of the #2 trigger buttons.
    • Lift the rear cover.
    • The #2 trigger buttons may come off when removing the cover.
  4. PlayStation Start and Select Buttons Replacement: adım 4, 2 resimden 1. PlayStation Start and Select Buttons Replacement: adım 4, 2 resimden 2.
    • Lift the battery and set it beside the controller, with care not to strain the wires.
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
  5. PlayStation Start and Select Buttons Replacement: adım 5, 2 resimden 1. PlayStation Start and Select Buttons Replacement: adım 5, 2 resimden 2.
    • Unclip the vibrating motors.
    • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
  6. PlayStation Start and Select Buttons Replacement: adım 6, 2 resimden 1. PlayStation Start and Select Buttons Replacement: adım 6, 2 resimden 2.
    • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
  7. PlayStation Start and Select Buttons Replacement: adım 7, 3 resimden 1. PlayStation Start and Select Buttons Replacement: adım 7, 3 resimden 2. PlayStation Start and Select Buttons Replacement: adım 7, 3 resimden 3.
    • Remove the rubber buttons with a pair of tweezers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 71
Her zaman: 1,563
