Ana içeriğe geç
PlayStation TV Thermal Pad Replacement
Neye ihtiyacın var
  1. PlayStation TV Thermal Pad Replacement, Motherboard: adım 1, 2 resimden 1. PlayStation TV Thermal Pad Replacement, Motherboard: adım 1, 2 resimden 2.
    • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
  2. PlayStation TV Thermal Pad Replacement: adım 2, 2 resimden 1. PlayStation TV Thermal Pad Replacement: adım 2, 2 resimden 2.
    • Remove the four 6 mm Phillips screws.
    • Remove the two Phillips #0 screws.
  3. PlayStation TV Thermal Pad Replacement: adım 3, 2 resimden 1. PlayStation TV Thermal Pad Replacement: adım 3, 2 resimden 2.
    • Remove the heat shield using the plastic opening tool.
    • Slide the tool around the edges until the shield is free.
  4. PlayStation TV Thermal Pad Replacement: adım 4, 2 resimden 1. PlayStation TV Thermal Pad Replacement: adım 4, 2 resimden 2.
    • Remove the last 6mm Phillips #0 screw from the motherboard.
  5. PlayStation TV Thermal Pad Replacement: adım 5, 2 resimden 1. PlayStation TV Thermal Pad Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
  6. PlayStation TV Thermal Pad Replacement, Thermal Pad: adım 6, 2 resimden 1. PlayStation TV Thermal Pad Replacement, Thermal Pad: adım 6, 2 resimden 2.
    • Remove the old thermal pad with an ESD safe tool, like a Jimmy.
  7. PlayStation TV Thermal Pad Replacement: adım 7, 2 resimden 1. PlayStation TV Thermal Pad Replacement: adım 7, 2 resimden 2.
    • Wipe down the area where the old thermal pads were located with rubbing alcohol.
    • It is important that the area be as clean as possible.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Theodore Hesse
145 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Baechle Spring 2016 IUPUI, Team 3-1, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S3G1
4 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
Photos for steps 6 through 9 will be posted soon!
Luk Davis - Yanıt
Do you replace the thermal pad? Your directions do not state where to do this, and if so what part and size do you recommend?
Daimonion - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 1,777
