Giriş
Over long periods of time and use, the manual adjustment wheel for the PlayStation VR headset can wear and the teeth can dull. This guide will assist with replacing the mechanical adjustment wheel for the PlayStation VR headset using basic household tools. While this project doesn't require a lot of tools, it does require a delicate touch when working with the headband and plastic tabs. If you are too rough with these parts they can become damaged and will require more maintenance.
Neye ihtiyacın var
Use your hands to remove the foam piece in the headband.
Use the iFixIt Opening Tool to pry the top and bottom trim pieces off of the rear band assembly.
