Ana içeriğe geç
PlayStation VR Processor Unit Cooling Fan Replacement
Neye ihtiyacın var
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: adım 1, 3 resimden 1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: adım 1, 3 resimden 2. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: adım 1, 3 resimden 3.
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: adım 2, 3 resimden 1. PlayStation VR Processor Unit Cooling Fan Replacement: adım 2, 3 resimden 2. PlayStation VR Processor Unit Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: adım 3, 2 resimden 1. PlayStation VR Processor Unit Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: adım 4, 3 resimden 1. PlayStation VR Processor Unit Cooling Fan Replacement: adım 4, 3 resimden 2. PlayStation VR Processor Unit Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: adım 6, 2 resimden 1. PlayStation VR Processor Unit Cooling Fan Replacement: adım 6, 2 resimden 2.
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: adım 7, 2 resimden 1. PlayStation VR Processor Unit Cooling Fan Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Sarah Shand
1.885 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G1
3 Üyeler
13 adet Kılavuz yazıldı
4 Yorum
Where do I get a replacement fan tho?
Ponos King - Yanıt
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - Yanıt
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 66
Her zaman: 8,766
