Ana içeriğe geç
PlayStation Vita Action Button Replacement
Neye ihtiyacın var
  1. PlayStation Vita Action Button Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita Action Button Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Action Button Replacement: adım 2, 3 resimden 1. PlayStation Vita Action Button Replacement: adım 2, 3 resimden 2. PlayStation Vita Action Button Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Action Button Replacement: adım 3, 2 resimden 1. PlayStation Vita Action Button Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Action Button Replacement: adım 4, 3 resimden 1. PlayStation Vita Action Button Replacement: adım 4, 3 resimden 2. PlayStation Vita Action Button Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Action Button Replacement: adım 5, 2 resimden 1. PlayStation Vita Action Button Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Action Button Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Action Button Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Action Button Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita Action Button Replacement, Wireless Card: adım 9, 3 resimden 1. PlayStation Vita Action Button Replacement, Wireless Card: adım 9, 3 resimden 2. PlayStation Vita Action Button Replacement, Wireless Card: adım 9, 3 resimden 3.
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Action Button Replacement: adım 10, 2 resimden 1. PlayStation Vita Action Button Replacement: adım 10, 2 resimden 2.
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Action Button Replacement: adım 11, 2 resimden 1. PlayStation Vita Action Button Replacement: adım 11, 2 resimden 2.
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Action Button Replacement, Right Shoulder Button: adım 12, 3 resimden 1. PlayStation Vita Action Button Replacement, Right Shoulder Button: adım 12, 3 resimden 2. PlayStation Vita Action Button Replacement, Right Shoulder Button: adım 12, 3 resimden 3.
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Action Button Replacement: adım 13, 1 resimden 1.
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Action Button Replacement: adım 14, 3 resimden 1. PlayStation Vita Action Button Replacement: adım 14, 3 resimden 2. PlayStation Vita Action Button Replacement: adım 14, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Action Button Replacement: adım 15, 2 resimden 1. PlayStation Vita Action Button Replacement: adım 15, 2 resimden 2.
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Action Button Replacement, Right Button Board: adım 16, 2 resimden 1. PlayStation Vita Action Button Replacement, Right Button Board: adım 16, 2 resimden 2.
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Action Button Replacement: adım 17, 2 resimden 1. PlayStation Vita Action Button Replacement: adım 17, 2 resimden 2.
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Action Button Replacement: adım 18, 3 resimden 1. PlayStation Vita Action Button Replacement: adım 18, 3 resimden 2. PlayStation Vita Action Button Replacement: adım 18, 3 resimden 3.
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Action Button Replacement: adım 19, 3 resimden 1. PlayStation Vita Action Button Replacement: adım 19, 3 resimden 2. PlayStation Vita Action Button Replacement: adım 19, 3 resimden 3.
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Action Button Replacement: adım 20, 3 resimden 1. PlayStation Vita Action Button Replacement: adım 20, 3 resimden 2. PlayStation Vita Action Button Replacement: adım 20, 3 resimden 3.
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Action Button Replacement, Action Button: adım 21, 3 resimden 1. PlayStation Vita Action Button Replacement, Action Button: adım 21, 3 resimden 2. PlayStation Vita Action Button Replacement, Action Button: adım 21, 3 resimden 3.
    • Using tweezers, gently peel the action button off the back casing assembly.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.739 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 135
Her zaman: 15,441
