Ana içeriğe geç
PlayStation Vita GPS Antenna Cable Replacement
Neye ihtiyacın var
  1. PlayStation Vita GPS Antenna Cable Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita GPS Antenna Cable Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita GPS Antenna Cable Replacement: adım 2, 3 resimden 1. PlayStation Vita GPS Antenna Cable Replacement: adım 2, 3 resimden 2. PlayStation Vita GPS Antenna Cable Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita GPS Antenna Cable Replacement: adım 3, 2 resimden 1. PlayStation Vita GPS Antenna Cable Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita GPS Antenna Cable Replacement: adım 4, 3 resimden 1. PlayStation Vita GPS Antenna Cable Replacement: adım 4, 3 resimden 2. PlayStation Vita GPS Antenna Cable Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita GPS Antenna Cable Replacement: adım 5, 2 resimden 1. PlayStation Vita GPS Antenna Cable Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita GPS Antenna Cable Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita GPS Antenna Cable Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita GPS Antenna Cable Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita GPS Antenna Cable Replacement, GPS Antenna Cable: adım 9, 1 resimden 1.
    • Using the pointy end of the spudger, gently pry the GPS antenna cable off the wireless card.
  10. PlayStation Vita GPS Antenna Cable Replacement: adım 10, 2 resimden 1. PlayStation Vita GPS Antenna Cable Replacement: adım 10, 2 resimden 2.
    • Using the pointy end of a spudger, gently pry the GPS antenna cable off of the motherboard.
    • Deroute the GPS antenna cable out of the casing and remove it.
Sonuç
Brittany McCrigler
89.128 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 4,614
