Ana içeriğe geç
PlayStation Vita Motherboard Replacement
Neye ihtiyacın var
  1. PlayStation Vita Motherboard Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita Motherboard Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Motherboard Replacement: adım 2, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 2, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Motherboard Replacement: adım 3, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Motherboard Replacement: adım 4, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 4, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Motherboard Replacement: adım 5, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Motherboard Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Motherboard Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita Motherboard Replacement, Wireless Card: adım 9, 3 resimden 1. PlayStation Vita Motherboard Replacement, Wireless Card: adım 9, 3 resimden 2. PlayStation Vita Motherboard Replacement, Wireless Card: adım 9, 3 resimden 3.
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Motherboard Replacement: adım 10, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 10, 2 resimden 2.
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Motherboard Replacement: adım 11, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Motherboard Replacement, Right Shoulder Button: adım 12, 3 resimden 1. PlayStation Vita Motherboard Replacement, Right Shoulder Button: adım 12, 3 resimden 2. PlayStation Vita Motherboard Replacement, Right Shoulder Button: adım 12, 3 resimden 3.
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Motherboard Replacement: adım 14, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 14, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 14, 3 resimden 3.
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Motherboard Replacement: adım 15, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 15, 2 resimden 2.
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Motherboard Replacement, Right Button Board: adım 16, 2 resimden 1. PlayStation Vita Motherboard Replacement, Right Button Board: adım 16, 2 resimden 2.
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Motherboard Replacement: adım 17, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 17, 2 resimden 2.
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Motherboard Replacement: adım 18, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 18, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 18, 3 resimden 3.
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Motherboard Replacement: adım 19, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 19, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 19, 3 resimden 3.
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Motherboard Replacement: adım 20, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 20, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 20, 3 resimden 3.
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Motherboard Replacement, Left Shoulder Button: adım 21, 3 resimden 1. PlayStation Vita Motherboard Replacement, Left Shoulder Button: adım 21, 3 resimden 2. PlayStation Vita Motherboard Replacement, Left Shoulder Button: adım 21, 3 resimden 3.
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  22. PlayStation Vita Motherboard Replacement: adım 22, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 22, 2 resimden 2.
    • Remove the translucent, plastic left shoulder button cover.
  23. PlayStation Vita Motherboard Replacement: adım 23, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 23, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 23, 3 resimden 3.
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  24. PlayStation Vita Motherboard Replacement: adım 24, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 24, 2 resimden 2.
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
  25. PlayStation Vita Motherboard Replacement, Left Button Board: adım 25, 2 resimden 1. PlayStation Vita Motherboard Replacement, Left Button Board: adım 25, 2 resimden 2.
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
  26. PlayStation Vita Motherboard Replacement: adım 26, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 26, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 26, 3 resimden 3.
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
  27. PlayStation Vita Motherboard Replacement: adım 27, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 27, 2 resimden 2.
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  28. PlayStation Vita Motherboard Replacement: adım 28, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 28, 2 resimden 2.
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  29. PlayStation Vita Motherboard Replacement: adım 29, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 29, 2 resimden 2.
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
  30. PlayStation Vita Motherboard Replacement: adım 30, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 30, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 30, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
  31. PlayStation Vita Motherboard Replacement: adım 31, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 31, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 31, 3 resimden 3.
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  32. PlayStation Vita Motherboard Replacement, Motherboard: adım 32, 2 resimden 1. PlayStation Vita Motherboard Replacement, Motherboard: adım 32, 2 resimden 2.
    • Using the pointy end of a spudger, pry up and release the GPS antenna cable from the motherboard.
    • Remove the GPS antenna cable.
  33. PlayStation Vita Motherboard Replacement: adım 33, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 33, 2 resimden 2.
    • Release the camera flex cable socket by prying up on the tab with a spudger.
  34. PlayStation Vita Motherboard Replacement: adım 34, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 34, 2 resimden 2.
    • Using a spudger, gently pry up on the camera.
    • Work your way under the camera and along the camera flex cable, using the spudger to peel away the adhesive, freeing the camera.
  35. PlayStation Vita Motherboard Replacement: adım 35, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 35, 2 resimden 2.
    • Carefully lift and remove the camera, sliding the flex cable out of the open connector socket.
  36. PlayStation Vita Motherboard Replacement: adım 36, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 36, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the 6.3mm screw beneath the camera.
    • Lift and remove the metal camera bracket.
  37. PlayStation Vita Motherboard Replacement: adım 37, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 37, 2 resimden 2.
    • With the help of a spudger, lift and release the tab on the blue flex cable socket.
  38. PlayStation Vita Motherboard Replacement: adım 38, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 38, 2 resimden 2.
    • Using tweezers, gently pull the blue power flex cable out of the socket; rest it out of the way.
  39. PlayStation Vita Motherboard Replacement: adım 39, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two pink, 4.4mm screws securing the motherboard.
  40. PlayStation Vita Motherboard Replacement: adım 40, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 40, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 40, 3 resimden 3.
    • Gently peel the rubber tab of the game port cover off the plastic casing pins.
    • Remove the game port cover.
  41. PlayStation Vita Motherboard Replacement: adım 41, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 41, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 41, 3 resimden 3.
    • Gently peel the rubber tab of the accessory port cover off the plastic casing pins.
    • Remove the accessory port cover.
  42. PlayStation Vita Motherboard Replacement: adım 42, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 42, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 42, 3 resimden 3.
    • Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly.
    • The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
  43. PlayStation Vita Motherboard Replacement: adım 43, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 43, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 43, 3 resimden 3.
    • Lift the motherboard out and identify the OLED connector still attaching the motherboard to the casing.
    • Holding the Vita on its side, use a spudger to gently pry off the OLED connector from the motherboard.
    • Be sure to hold the motherboard while you release the connector as this will free the motherboard. If you are not holding the motherboard, it will fall.
  44. PlayStation Vita Motherboard Replacement: adım 44, 1 resimden 1.
    • Completely separate the motherboard from the case. Remove the case.
  45. PlayStation Vita Motherboard Replacement: adım 45, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 45, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 45, 3 resimden 3.
    • Starting at the right side, gently lift and remove the black casing that once held the camera.
  46. PlayStation Vita Motherboard Replacement: adım 46, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 46, 2 resimden 2.
    • Using a spudger, release the tab on the ZIF connector located above the two screw posts where the wireless card once was.
  47. PlayStation Vita Motherboard Replacement: adım 47, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 47, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 47, 3 resimden 3.
    • Gently pull the flex cable out of the ZIF connector, and remove it.
  48. PlayStation Vita Motherboard Replacement: adım 48, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 48, 2 resimden 2.
    • Release the tab on the large ZIF connector on the right side of the motherboard by lifting the tab with a spudger.
  49. PlayStation Vita Motherboard Replacement: adım 49, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 49, 2 resimden 2.
  50. PlayStation Vita Motherboard Replacement: adım 50, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 50, 2 resimden 2.
    • Using a spudger, release the small ZIF connector on the right side of the motherboard.
  51. PlayStation Vita Motherboard Replacement: adım 51, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 51, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 51, 3 resimden 3.
    • Gently pull the flex cable out of the small ZIF connector, and remove it.
  52. PlayStation Vita Motherboard Replacement: adım 52, 2 resimden 1. PlayStation Vita Motherboard Replacement: adım 52, 2 resimden 2.
    • Flip the motherboard over.
    • With the help of a spudger, pry up and release the tab of the rear camera flex cable connector.
  53. PlayStation Vita Motherboard Replacement: adım 53, 3 resimden 1. PlayStation Vita Motherboard Replacement: adım 53, 3 resimden 2. PlayStation Vita Motherboard Replacement: adım 53, 3 resimden 3.
    • Gently pull the rear camera out of the connector and remove it.
  54. PlayStation Vita Motherboard Replacement: adım 54, 1 resimden 1.
    • The motherboard remains.
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
88.791 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
15.200 adet Kılavuz yazıldı
11 Yorum
in steps 2&3, bottom is top and top is bottom
Samir Al Jubori - Yanıt
it should be noted that the memory card should always be taken out before separating the case. I just broke my memory card slot by having a card in there while I was opening the case, there's a tiny bit of overhang that will pull the slot off the motherboard.
bryandodson - Yanıt
does anyone know what firmware version the motherboard comes with?
riddochj - Yanıt
These are used Motherboards. You could get a motherboards with a random FW version.
Raheem -
Okay My original Motherboard power connector broke. So nothing was wrong with it except the Power connector.
My first buy of the Motherboard screen connector broke off.
The Replacement works well, however the Touch input isn't working, unless I restore the device. After a certain amount of time it becomes unresponsive.
Do anyone have a fix before I get a 3rd replacement.
Raheem - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 66
Son 30 gün: 286
Her zaman: 62,063
