Ana içeriğe geç
PlayStation Vita Rear Panel Replacement
Neye ihtiyacın var
  1. PlayStation Vita Rear Panel Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita Rear Panel Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Panel Replacement: adım 2, 3 resimden 1. PlayStation Vita Rear Panel Replacement: adım 2, 3 resimden 2. PlayStation Vita Rear Panel Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Panel Replacement: adım 3, 2 resimden 1. PlayStation Vita Rear Panel Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Panel Replacement: adım 4, 3 resimden 1. PlayStation Vita Rear Panel Replacement: adım 4, 3 resimden 2. PlayStation Vita Rear Panel Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Panel Replacement: adım 5, 2 resimden 1. PlayStation Vita Rear Panel Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Yanıt
  6. PlayStation Vita Rear Panel Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Panel Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Yanıt
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Yanıt
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Yanıt
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Yanıt
    broke the white part
    Benaya Miller - Yanıt
  8. PlayStation Vita Rear Panel Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Panel Replacement, Battery: adım 9, 2 resimden 1. PlayStation Vita Rear Panel Replacement, Battery: adım 9, 2 resimden 2.
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
    Using the tabs (I could really only see one) on the side of the retainer proved essential for me to remove it and release the cable. Unless that happened that cable retainer was not moving for me at all. It did come out once the tabs were pressed though they did prove somewhat uncooperative with clicking back into place once I had installed the new battery. Also, watch that the battery’s cable isn’t pinched when you’re putting everything back in place.
    klung - Yanıt
  10. PlayStation Vita Rear Panel Replacement: adım 10, 2 resimden 1. PlayStation Vita Rear Panel Replacement: adım 10, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
    When reinstalling the battery retaining bar, be sure to insert the bottom end (as shown in the photo) into the slot before driving in the screws. If you just lay it on top, you will crack the bar.
    Lee Johnson - Yanıt
  11. PlayStation Vita Rear Panel Replacement: adım 11, 3 resimden 1. PlayStation Vita Rear Panel Replacement: adım 11, 3 resimden 2. PlayStation Vita Rear Panel Replacement: adım 11, 3 resimden 3.
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
  12. PlayStation Vita Rear Panel Replacement, Rear Panel: adım 12, 3 resimden 1. PlayStation Vita Rear Panel Replacement, Rear Panel: adım 12, 3 resimden 2. PlayStation Vita Rear Panel Replacement, Rear Panel: adım 12, 3 resimden 3.
    • Slide the spuder between the right speaker and the rear casing.
    • Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
    • Remove the right speaker.
  13. PlayStation Vita Rear Panel Replacement: adım 13, 3 resimden 1. PlayStation Vita Rear Panel Replacement: adım 13, 3 resimden 2. PlayStation Vita Rear Panel Replacement: adım 13, 3 resimden 3.
    • Slide the spudger between the left speaker and the rear casing.
    • Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
    • Remove the left speaker.
  14. PlayStation Vita Rear Panel Replacement: adım 14, 1 resimden 1.
    • The rear panel remains.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
88.930 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
5 Yorum
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
Daniel - Yanıt
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
I can't get pass Step 1. I can take out the bottom left screw of the rear touchpad but I can't take out the other 3. I bought a used Vita and there is a screw that turns but does not gout up. What should I do?
kken07655 - Yanıt
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Kamil Dębiec - Yanıt
Those are wifi antennas. You can get it out put it in to the new panel.
repairguy69 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 74
Son 30 gün: 347
Her zaman: 30,221
