Ana içeriğe geç
PlayStation Vita Right Button Board Replacement
Neye ihtiyacın var
  1. PlayStation Vita Right Button Board Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita Right Button Board Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Button Board Replacement: adım 2, 3 resimden 1. PlayStation Vita Right Button Board Replacement: adım 2, 3 resimden 2. PlayStation Vita Right Button Board Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Button Board Replacement: adım 3, 2 resimden 1. PlayStation Vita Right Button Board Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Button Board Replacement: adım 4, 3 resimden 1. PlayStation Vita Right Button Board Replacement: adım 4, 3 resimden 2. PlayStation Vita Right Button Board Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Button Board Replacement: adım 5, 2 resimden 1. PlayStation Vita Right Button Board Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Button Board Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Button Board Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Button Board Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita Right Button Board Replacement, Wireless Card: adım 9, 3 resimden 1. PlayStation Vita Right Button Board Replacement, Wireless Card: adım 9, 3 resimden 2. PlayStation Vita Right Button Board Replacement, Wireless Card: adım 9, 3 resimden 3.
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Button Board Replacement: adım 10, 2 resimden 1. PlayStation Vita Right Button Board Replacement: adım 10, 2 resimden 2.
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Button Board Replacement: adım 11, 2 resimden 1. PlayStation Vita Right Button Board Replacement: adım 11, 2 resimden 2.
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: adım 12, 3 resimden 1. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: adım 12, 3 resimden 2. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: adım 12, 3 resimden 3.
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Button Board Replacement: adım 13, 1 resimden 1.
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Button Board Replacement: adım 14, 3 resimden 1. PlayStation Vita Right Button Board Replacement: adım 14, 3 resimden 2. PlayStation Vita Right Button Board Replacement: adım 14, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Button Board Replacement: adım 15, 2 resimden 1. PlayStation Vita Right Button Board Replacement: adım 15, 2 resimden 2.
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Button Board Replacement, Right Button Board: adım 16, 2 resimden 1. PlayStation Vita Right Button Board Replacement, Right Button Board: adım 16, 2 resimden 2.
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Button Board Replacement: adım 17, 2 resimden 1. PlayStation Vita Right Button Board Replacement: adım 17, 2 resimden 2.
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Button Board Replacement: adım 18, 3 resimden 1. PlayStation Vita Right Button Board Replacement: adım 18, 3 resimden 2. PlayStation Vita Right Button Board Replacement: adım 18, 3 resimden 3.
    Satın Al
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Button Board Replacement: adım 19, 3 resimden 1. PlayStation Vita Right Button Board Replacement: adım 19, 3 resimden 2. PlayStation Vita Right Button Board Replacement: adım 19, 3 resimden 3.
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Button Board Replacement: adım 20, 3 resimden 1. PlayStation Vita Right Button Board Replacement: adım 20, 3 resimden 2. PlayStation Vita Right Button Board Replacement: adım 20, 3 resimden 3.
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brittany McCrigler
89.128 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 55
Her zaman: 7,948
