Ana içeriğe geç
PlayStation Vita Right Shoulder Button Replacement
Neye ihtiyacın var
  1. PlayStation Vita Right Shoulder Button Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita Right Shoulder Button Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Shoulder Button Replacement: adım 2, 3 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 2, 3 resimden 2. PlayStation Vita Right Shoulder Button Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Shoulder Button Replacement: adım 3, 2 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Shoulder Button Replacement: adım 4, 3 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 4, 3 resimden 2. PlayStation Vita Right Shoulder Button Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Shoulder Button Replacement: adım 5, 2 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Yanıt
  6. PlayStation Vita Right Shoulder Button Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Shoulder Button Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Yanıt
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Yanıt
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Yanıt
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Yanıt
    broke the white part
    Benaya Miller - Yanıt
  8. PlayStation Vita Right Shoulder Button Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita Right Shoulder Button Replacement, Wireless Card: adım 9, 3 resimden 1. PlayStation Vita Right Shoulder Button Replacement, Wireless Card: adım 9, 3 resimden 2. PlayStation Vita Right Shoulder Button Replacement, Wireless Card: adım 9, 3 resimden 3.
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
    Step 9-11 only apply to the 3G version of the PS Vita.
    logicj83 - Yanıt
    Hello, I have the PCH-2001 model of the PS vita and the right analog stick went out. I ordered a replacement and the stick is slightly larger than the original. The original has a black rectangle on the back, the new version has the star version, which is what you have on this website as the replacement part. Any help here would be much appreciated. Thanks.
    Ben Ragains - Yanıt
    Can I install a WiFi motherboard on a 3g ps vita model 1100?
    fmind11 - Yanıt
  10. PlayStation Vita Right Shoulder Button Replacement: adım 10, 2 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 10, 2 resimden 2.
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Shoulder Button Replacement: adım 11, 2 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 11, 2 resimden 2.
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
    My screwdriver does not want to unscrew those. They won’t turn at all.
    Rei - Yanıt
    Got the same, used PH #0 and grabbed wireless card casing with fingers from the top to release pressure on screen and avoid (possibly) breaking it.
    Yuriy Zhyromskiy - Yanıt
    Some PS vita models seem to use a T2 screw instead of a PH#00. I’ve encountered this twice now.
    kaosjr kaosjr - Yanıt
    I replaced de wifi card but is still difficult to connect to wifi. Could it be the wifi antenna? which cable model is it?
    Fernando Diaz - Yanıt
    3G Vita 1000.
    I found that the PH00 head wouldn't actually fit in to the screw correctly. A PH000 fit but was still requiring a bit more force than seemed necessary. Also the card did not pop up when the screws were released and that's because Sony used a tacky pad under the card so needed a bit of prying up to get the angle.
    Paul Pimm - Yanıt
  12. PlayStation Vita Right Shoulder Button Replacement, Right Shoulder Button: adım 12, 3 resimden 1. PlayStation Vita Right Shoulder Button Replacement, Right Shoulder Button: adım 12, 3 resimden 2. PlayStation Vita Right Shoulder Button Replacement, Right Shoulder Button: adım 12, 3 resimden 3.
    • Pry up the right shoulder button casing with a spudger and set it aside.
    Is this really necessary?
    fmind11 - Yanıt
  13. PlayStation Vita Right Shoulder Button Replacement: adım 13, 1 resimden 1.
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Shoulder Button Replacement: adım 14, 3 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 14, 3 resimden 2. PlayStation Vita Right Shoulder Button Replacement: adım 14, 3 resimden 3.
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Shoulder Button Replacement: adım 15, 2 resimden 1. PlayStation Vita Right Shoulder Button Replacement: adım 15, 2 resimden 2.
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.012 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.767 adet Kılavuz yazıldı
5 Yorum
Is anyone else experiencing the button getting stuck?
Fantasy Silicone Statuettes - Yanıt
Yes, mine is getting stuck, too. I am hoping a replacement will solve this problem.
aseelau -
Has anyone experienced or seen an issue where the trigger button acts with the same functionality as the home button. Every time I press the right trigger it exits to home or exits the game.....help please
Daniel - Yanıt
I followed this guide on my 3G vita in order to replace the right trigger cable. I found it wasn't necessary to remove the wireless card if anyone else finds that part tricky.
Caleb - Yanıt
i am replacing the whole front part of my vita do to screen cracked and wont turn on, when i put the button back on, how would i do so to make it stick back on? would i need to reglue it or will it stick back on by itself?
Saul Calderon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 116
Her zaman: 14,432
