Ana içeriğe geç
PlayStation Vita Speakers Replacement
Neye ihtiyacın var
  1. PlayStation Vita Speakers Replacement, Case Separation: adım 1, 2 resimden 1. PlayStation Vita Speakers Replacement, Case Separation: adım 1, 2 resimden 2.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Speakers Replacement: adım 2, 3 resimden 1. PlayStation Vita Speakers Replacement: adım 2, 3 resimden 2. PlayStation Vita Speakers Replacement: adım 2, 3 resimden 3.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Speakers Replacement: adım 3, 2 resimden 1. PlayStation Vita Speakers Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Speakers Replacement: adım 4, 3 resimden 1. PlayStation Vita Speakers Replacement: adım 4, 3 resimden 2. PlayStation Vita Speakers Replacement: adım 4, 3 resimden 3.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Speakers Replacement: adım 5, 2 resimden 1. PlayStation Vita Speakers Replacement: adım 5, 2 resimden 2.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Speakers Replacement: adım 6, 1 resimden 1.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Speakers Replacement: adım 7, 1 resimden 1.
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Speakers Replacement: adım 8, 1 resimden 1.
    • Separate the front and rear cases.
  9. PlayStation Vita Speakers Replacement, Speakers: adım 9, 2 resimden 1. PlayStation Vita Speakers Replacement, Speakers: adım 9, 2 resimden 2.
    • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
    • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.012 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.764 adet Kılavuz yazıldı
2 Yorum
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - Yanıt
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 16
Son 30 gün: 101
Her zaman: 12,176
