Giriş
This guide takes you through installing the speakers in the PlayStation Vita.
Neye ihtiyacın var
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Free the battery cable by gently prying up on the connection with a spudger.
Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
Yea I messed up there too. Is there a way to fix it?
This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
broke the white part
Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
What is that little connection point for, just above where the speaker sits. it has a single connection point on the side motherboard.
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
