Ana içeriğe geç
Playstation 3 Fan Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Playstation 3 Fan Replacement, Top Cover: adım 1, 2 resimden 1. Playstation 3 Fan Replacement, Top Cover: adım 1, 2 resimden 2.
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Fan Replacement: adım 3, 2 resimden 1. Playstation 3 Fan Replacement: adım 3, 2 resimden 2.
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Fan Replacement: adım 4, 2 resimden 1. Playstation 3 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Fan Replacement: adım 5, 3 resimden 1. Playstation 3 Fan Replacement: adım 5, 3 resimden 2. Playstation 3 Fan Replacement: adım 5, 3 resimden 3.
    • You can now lift off the top cover.
  6. Playstation 3 Fan Replacement, Power Supply: adım 6, 2 resimden 1. Playstation 3 Fan Replacement, Power Supply: adım 6, 2 resimden 2.
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Fan Replacement: adım 7, 1 resimden 1.
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Fan Replacement: adım 8, 2 resimden 1. Playstation 3 Fan Replacement: adım 8, 2 resimden 2.
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Fan Replacement, Motherboard Enclosure: adım 9, 2 resimden 1. Playstation 3 Fan Replacement, Motherboard Enclosure: adım 9, 2 resimden 2.
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Fan Replacement: adım 10, 2 resimden 1. Playstation 3 Fan Replacement: adım 10, 2 resimden 2.
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Fan Replacement: adım 11, 1 resimden 1.
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Fan Replacement: adım 12, 3 resimden 1. Playstation 3 Fan Replacement: adım 12, 3 resimden 2. Playstation 3 Fan Replacement: adım 12, 3 resimden 3.
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Fan Replacement, Fan: adım 13, 1 resimden 1.
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
iDeleted
2.101 İtibar
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,849
