Ana içeriğe geç
Playstation Classic Controller Cord Replacement
Neye ihtiyacın var
  1. Playstation Classic Controller Cord Replacement, Controller Cord: adım 1, 3 resimden 1. Playstation Classic Controller Cord Replacement, Controller Cord: adım 1, 3 resimden 2. Playstation Classic Controller Cord Replacement, Controller Cord: adım 1, 3 resimden 3.
    • Turn the controller over so that the screws are facing up.
  2. Playstation Classic Controller Cord Replacement: adım 2, 1 resimden 1.
    • Use a small Phillips #0 screwdriver to remove the eight Xmm screws.
    • Make sure to store the screws in a safe place so they are not lost before reassembly.
  3. Playstation Classic Controller Cord Replacement: adım 3, 3 resimden 1. Playstation Classic Controller Cord Replacement: adım 3, 3 resimden 2. Playstation Classic Controller Cord Replacement: adım 3, 3 resimden 3.
    • Use the Jimmy tool to take the back part off and get into the controller.
    • It shouldn’t take too much force to remove the back part. Make sure all screws are taken out beforehand so you avoid hurting yourself or damaging the controller.
  4. Playstation Classic Controller Cord Replacement: adım 4, 1 resimden 1.
    • You will notice that the controller cord is plugged into a Micro USB port on the controller motherboard.
  5. Playstation Classic Controller Cord Replacement: adım 5, 3 resimden 1. Playstation Classic Controller Cord Replacement: adım 5, 3 resimden 2. Playstation Classic Controller Cord Replacement: adım 5, 3 resimden 3.
    • To unplug the cord from the controller motherboard, carefully take the cord out from in between the small pegs that it is nestled into.
    • When unplugging the cord, hold the controller so that no significant pressure is being applied to the motherboard that will damage it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Maxwell Webb
685 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G8
2 Üyeler
23 adet Kılavuz yazıldı
2 Yorum
Will this fix the controller being unresponsive?
Jamal Saeed - Yanıt
maybe but It depends
enrique bengaura -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 50
Her zaman: 6,780
