Ana içeriğe geç
Playstation Classic Open Button Replacement
Neye ihtiyacın var
  1. Playstation Classic Open Button Replacement, Motherboard: adım 1, 1 resimden 1.
    • Flip the console so its back is facing up.
  2. Playstation Classic Open Button Replacement: adım 2, 1 resimden 1.
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Open Button Replacement: adım 3, 3 resimden 1. Playstation Classic Open Button Replacement: adım 3, 3 resimden 2. Playstation Classic Open Button Replacement: adım 3, 3 resimden 3.
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Open Button Replacement: adım 4, 1 resimden 1.
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Open Button Replacement: adım 5, 3 resimden 1. Playstation Classic Open Button Replacement: adım 5, 3 resimden 2. Playstation Classic Open Button Replacement: adım 5, 3 resimden 3.
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Open Button Replacement: adım 6, 3 resimden 1. Playstation Classic Open Button Replacement: adım 6, 3 resimden 2. Playstation Classic Open Button Replacement: adım 6, 3 resimden 3.
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. Playstation Classic Open Button Replacement, Open Button: adım 7, 3 resimden 1. Playstation Classic Open Button Replacement, Open Button: adım 7, 3 resimden 2. Playstation Classic Open Button Replacement, Open Button: adım 7, 3 resimden 3.
    • Remove the motherboard using the previous guide and isolate the top shell of the casing.
    • Use the Spudger to apply pressure inwards on the three plastic clips highlighted in the red circles.
  8. Playstation Classic Open Button Replacement: adım 8, 3 resimden 1. Playstation Classic Open Button Replacement: adım 8, 3 resimden 2. Playstation Classic Open Button Replacement: adım 8, 3 resimden 3.
    • After all three clips are pushed in, apply pressure on the cylindrical piece circled in red.
    • Push softly on the button till a small gap is created on the other side.
    • You are not trying to fully remove the Open Button in this step.
  9. Playstation Classic Open Button Replacement: adım 9, 3 resimden 1. Playstation Classic Open Button Replacement: adım 9, 3 resimden 2. Playstation Classic Open Button Replacement: adım 9, 3 resimden 3.
    • Use the black spudger to softly pry out the open button from the top of the casing.
    • Once enough of a gap has been created, use your fingers to grab and slowly remove the open piece.
    • An unrestrained string is under the open button and can fall out easily. To avoid losing the spring, complete this step on a flat surface and be gentle while removing the open button.
Sonuç
Maxwell Webb
685 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G8
2 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 1,339
