Ana içeriğe geç
Playstation Controller Fast Fix
Neye ihtiyacın var
  1. Playstation Controller Fast Fix, Power Off and Disconnect: adım 1, 1 resimden 1.
    • Turn off the controller and disconnect it.
    FixBot'a Sor
    Yorum Ekle
  2. Playstation Controller Fast Fix, Gather Tools: adım 2, 1 resimden 1.
    • Prepare tools including a precision screwdriver set, plastic pry tool, tweezers, isopropyl alcohol, and cotton swabs.
    FixBot'a Sor
    Yorum Ekle
  3. Playstation Controller Fast Fix, Remove Outer Screws: adım 3, 1 resimden 1.
    • Locate and remove all screws from the controller casing using a screwdriver. top and bottom.
    FixBot'a Sor
    Yorum Ekle
  4. Playstation Controller Fast Fix, Open the Controller Housing: adım 4, 1 resimden 1.
    • Carefully pry open the controller using a plastic tool to avoid damaging components.
    FixBot'a Sor
    Yorum Ekle
  5. Playstation Controller Fast Fix, Disconnect Internal Components: adım 5, 1 resimden 1.
    • Gently detach the battery and ribbon cables to access the motherboard, and then unscrew the motherboard retainer(black cover)
    FixBot'a Sor
    Yorum Ekle
  6. Playstation Controller Fast Fix, Locate the Analog Stick Module: adım 6, 1 resimden 1.
    • Identify the joystick assembly attached to the circuit board. Note: look hard for this one. It's a bit small
    FixBot'a Sor
    Yorum Ekle
  7. Playstation Controller Fast Fix, Clean the Potentiometers: adım 7, 1 resimden 1.
    • Apply isopropyl alcohol to the base of the analog stick and rotate it to remove dirt and other stuff. Note: be careful on how hard you clean with the swabs, and don't apply too much rubbing alcohol.
    FixBot'a Sor
    Yorum Ekle
  8. Playstation Controller Fast Fix, Reassemble and Test: adım 8, 1 resimden 1.
    • Reconnect all components, close the controller, and test it to ensure the stick drift is resolved. Note: since the battery was removed during the procedure, charging the controller is a must after putting it back together.
    FixBot'a Sor
    Yorum Ekle
  9. Playstation Controller Fast Fix, Reassemble and Test: adım 9, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Aaron Ruiz
61 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 57
Son 7 gün: 205
Son 30 gün: 789
Her zaman: 2,099
