Ana içeriğe geç
Plum Optimax 10 Headphone Jack Replacement
Neye ihtiyacın var
  1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: adım 1, 2 resimden 1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Headphone Jack  Replacement: adım 2, 2 resimden 1. Plum Optimax 10 Headphone Jack  Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: adım 3, 3 resimden 1. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: adım 3, 3 resimden 2. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: adım 3, 3 resimden 3.
    • Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
    • Use a plastic opening tool to pry up the headphone jack from its place in the case.
    • The headphone jack is lightly adhered to the back case.
    • When removing the jack, be gentle with the ribbon wire because it is capable of tearing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 90
