Ana içeriğe geç
Pneumatic Door Closer Replacement
Neye ihtiyacın var
  1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: adım 1, 2 resimden 1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: adım 1, 2 resimden 2.
    • Identify the broken part of the door.
  2. Pneumatic Door Closer Replacement: adım 2, 2 resimden 1. Pneumatic Door Closer Replacement: adım 2, 2 resimden 2.
    • Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
  3. Pneumatic Door Closer Replacement: adım 3, 3 resimden 1. Pneumatic Door Closer Replacement: adım 3, 3 resimden 2. Pneumatic Door Closer Replacement: adım 3, 3 resimden 3.
    • Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
  4. Pneumatic Door Closer Replacement: adım 4, 2 resimden 1. Pneumatic Door Closer Replacement: adım 4, 2 resimden 2.
    • Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
  5. Pneumatic Door Closer Replacement: adım 5, 3 resimden 1. Pneumatic Door Closer Replacement: adım 5, 3 resimden 2. Pneumatic Door Closer Replacement: adım 5, 3 resimden 3.
    • Plug the smallest included screw into the inner bracket to attach the door closer.
  6. Pneumatic Door Closer Replacement: adım 6, 3 resimden 1. Pneumatic Door Closer Replacement: adım 6, 3 resimden 2. Pneumatic Door Closer Replacement: adım 6, 3 resimden 3.
    • Close the door.
    • Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
  7. Pneumatic Door Closer Replacement: adım 7, 3 resimden 1. Pneumatic Door Closer Replacement: adım 7, 3 resimden 2. Pneumatic Door Closer Replacement: adım 7, 3 resimden 3.
    • Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
  8. Pneumatic Door Closer Replacement: adım 8, 2 resimden 1. Pneumatic Door Closer Replacement: adım 8, 2 resimden 2.
    • Make sure the door closes and opens properly.
    • Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
Bitiş Çizgisi
Abdullah Kaddura
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 580
