Ana içeriğe geç
Pocket Knife Wooden Casing Replacement
Neye ihtiyacın var
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: adım 1, 2 resimden 1. Pocket Knife Wooden Casing Replacement, Wooden Casing: adım 1, 2 resimden 2.
    • Trace the knife outline onto wood.
  2. Pocket Knife Wooden Casing Replacement: adım 2, 2 resimden 1. Pocket Knife Wooden Casing Replacement: adım 2, 2 resimden 2.
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
  3. Pocket Knife Wooden Casing Replacement: adım 3, 2 resimden 1. Pocket Knife Wooden Casing Replacement: adım 3, 2 resimden 2.
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
  4. Pocket Knife Wooden Casing Replacement: adım 4, 3 resimden 1. Pocket Knife Wooden Casing Replacement: adım 4, 3 resimden 2. Pocket Knife Wooden Casing Replacement: adım 4, 3 resimden 3.
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
  5. Pocket Knife Wooden Casing Replacement: adım 5, 2 resimden 1. Pocket Knife Wooden Casing Replacement: adım 5, 2 resimden 2.
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
  6. Pocket Knife Wooden Casing Replacement: adım 6, 3 resimden 1. Pocket Knife Wooden Casing Replacement: adım 6, 3 resimden 2. Pocket Knife Wooden Casing Replacement: adım 6, 3 resimden 3.
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 362
