Ana içeriğe geç
Pokémon™ GO Plus+ Faceplate Removal
Neye ihtiyacın var
  1. Pokémon™ GO Plus+ Faceplate Removal, Remove the two screws from the bottom: adım 1, 1 resimden 1.
    • Flanking both sides of the charging port are J00 Screws. Remove these.
    • These screws go into plastic, so when re-assembling the device, be very careful not to over tighten them.
    • These two screws are identical to each other, but differ from the screws within the device, keep them separate from any screws you remove from within the device.
  2. Pokémon™ GO Plus+ Faceplate Removal, Remove Faceplace: adım 2, 2 resimden 1. Pokémon™ GO Plus+ Faceplate Removal, Remove Faceplace: adım 2, 2 resimden 2.
    • When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
    • While opening, be extremely careful not to damage the fragile cables and connection between the main body and the faceplate.
    • With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
    • There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
Sonuç
To re-assemble, simply follow these directions in reverse!
2 farklı kişi bu kılavuzu tamamladı.
David
714 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 122
Her zaman: 844
