Giriş
The Pokemon Go Plus+ uses the same battery replacement as the Nintendo Switch Official Joy-Cons, so finding the battery should be very easy!
Neye ihtiyacın var
Flanking both sides of the charging port are J00 Screws. Remove these.
When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
Normally you'd disconnect the battery first, but with this device we cannot reach the connector until we remove the battery cover.
This connector is the same one on the Nintendo Joy-Cons, this connector has no retention clip, and must be pried upward to remove it.
The battery is attached to the cover with some adhesive, use your spudger to carefully and gently lever it off the cover.
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Do you need to solder the wires into the new battery, or is it just a clip system?
There is a connector, it's not soldered. It's the exact same part and connector is the official joycon batteries.
David -
