Ana içeriğe geç
Polar M400 Watch Battery Replacement
Neye ihtiyacın var
  1. Polar M400 Watch Battery Replacement, Wrist Strap: adım 1, 1 resimden 1.
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Battery Replacement: adım 2, 2 resimden 1. Polar M400 Watch Battery Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Battery Replacement: adım 3, 1 resimden 1.
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Battery Replacement: adım 5, 2 resimden 1. Polar M400 Watch Battery Replacement: adım 5, 2 resimden 2.
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Battery Replacement: adım 6, 2 resimden 1. Polar M400 Watch Battery Replacement: adım 6, 2 resimden 2.
    Satın Al
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Nicholas Sanders
513 İtibar
2 adet Kılavuz yazıldı
Ekip
25 Yorum
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Yanıt
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman -
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Yanıt
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Yanıt
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 45
Son 30 gün: 202
Her zaman: 30,144
