Giriş
This guide will show users how to remove and replace the watch band on the Polar V800 sports watch. If the watch band needs to be swapped for a different sized watch band or the watch band is broken or wearing out, this is the perfect guide to putting your watch back where it belongs (on your wrist!).
Neye ihtiyacın var
Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
Completely pull out the pins.
Bir başkası bu kılavuzu tamamladı.
8 Yorum
There is no way for me to remove the clips, they are stuck and don’t move, any ideas on how to loosen them?
I have the same issue. Any idea?
No, I guess I won’t Be buying Polar stuff no more… can’t believe it…
The Pins move out! Like described above, there is one side with a larger head of the pin. This is the side where the pin comes out. The smaller side is where you push. Due to water and sweat, there is some kind off corrosion or buildup around the pin.This is why it does not come out easy. Important is to use right size of the tool. Lubrication with WD40 silicone oil helps.
