Ana içeriğe geç
Polaroid A10 Battery Replacement
Neye ihtiyacın var
    1. Polaroid A10 Battery Replacement, Back Cover: adım 1, 3 resimden 1. Polaroid A10 Battery Replacement, Back Cover: adım 1, 3 resimden 2. Polaroid A10 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Polaroid A10 Battery Replacement, Battery: adım 2, 3 resimden 1. Polaroid A10 Battery Replacement, Battery: adım 2, 3 resimden 2. Polaroid A10 Battery Replacement, Battery: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid A10 Battery Replacement: adım 3, 3 resimden 1. Polaroid A10 Battery Replacement: adım 3, 3 resimden 2. Polaroid A10 Battery Replacement: adım 3, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid A10 Battery Replacement: adım 4, 1 resimden 1.
      • Gently lift the battery up and out of the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
armando
150 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G3
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 1,161
