Ana içeriğe geç
Polaroid A10 Front/Back Camera Replacement
Neye ihtiyacın var
  1. Polaroid A10 Front/Back Camera Replacement, Back Cover: adım 1, 3 resimden 1. Polaroid A10 Front/Back Camera Replacement, Back Cover: adım 1, 3 resimden 2. Polaroid A10 Front/Back Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Front/Back Camera Replacement, Battery: adım 2, 3 resimden 1. Polaroid A10 Front/Back Camera Replacement, Battery: adım 2, 3 resimden 2. Polaroid A10 Front/Back Camera Replacement, Battery: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Front/Back Camera Replacement: adım 3, 3 resimden 1. Polaroid A10 Front/Back Camera Replacement: adım 3, 3 resimden 2. Polaroid A10 Front/Back Camera Replacement: adım 3, 3 resimden 3.
  4. Polaroid A10 Front/Back Camera Replacement: adım 4, 1 resimden 1.
    • Gently lift the battery up and out of the device.
  5. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: adım 5, 1 resimden 1.
    • The camera head is located on the upper middle section of the device, close to the battery.
  6. Polaroid A10 Front/Back Camera Replacement: adım 6, 2 resimden 1. Polaroid A10 Front/Back Camera Replacement: adım 6, 2 resimden 2.
    • Start by locating the two left and right screws which hold the camera head in place.
    • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
  7. Polaroid A10 Front/Back Camera Replacement: adım 7, 3 resimden 1. Polaroid A10 Front/Back Camera Replacement: adım 7, 3 resimden 2. Polaroid A10 Front/Back Camera Replacement: adım 7, 3 resimden 3.
    • Locate the camera ribbon cable that is connected to the motherboard.
    • With a spudger, remove the camera ribbon cable base from the motherboard connector.
    • With one finger, delicately remove the camera ribbon cable by sliding down.
Sonuç
Shilpa Verma
353 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 229
