Ana içeriğe geç
Polaroid A10 Motherboard Replacement
Neye ihtiyacın var
  1. Polaroid A10 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Polaroid A10 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Polaroid A10 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: adım 2, 3 resimden 1. Polaroid A10 Motherboard Replacement, Motherboard: adım 2, 3 resimden 2. Polaroid A10 Motherboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: adım 3, 3 resimden 1. Polaroid A10 Motherboard Replacement: adım 3, 3 resimden 2. Polaroid A10 Motherboard Replacement: adım 3, 3 resimden 3.
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: adım 4, 2 resimden 1. Polaroid A10 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: adım 5, 3 resimden 1. Polaroid A10 Motherboard Replacement: adım 5, 3 resimden 2. Polaroid A10 Motherboard Replacement: adım 5, 3 resimden 3.
    • Gently lift the motherboard up and out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tracie
119 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 587
