Ana içeriğe geç
Polaroid A10 Speakers Replacement
Neye ihtiyacın var
  1. Polaroid A10 Speakers Replacement, Back Cover: adım 1, 3 resimden 1. Polaroid A10 Speakers Replacement, Back Cover: adım 1, 3 resimden 2. Polaroid A10 Speakers Replacement, Back Cover: adım 1, 3 resimden 3.
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: adım 2, 1 resimden 1.
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: adım 3, 3 resimden 1. Polaroid A10 Speakers Replacement: adım 3, 3 resimden 2. Polaroid A10 Speakers Replacement: adım 3, 3 resimden 3.
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: adım 4, 1 resimden 1.
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: adım 5, 1 resimden 1.
    • Gently lift the speakers up and out of the device.
Sonuç
Koby
104 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G3
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - Yanıt
If the wires and out of the
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 231
