Ana içeriğe geç
Polaroid Automatic 100 Bellows Replacement
Neye ihtiyacın var
  1. Polaroid Automatic 100 Bellows Replacement, Bellows: adım 1, 3 resimden 1. Polaroid Automatic 100 Bellows Replacement, Bellows: adım 1, 3 resimden 2. Polaroid Automatic 100 Bellows Replacement, Bellows: adım 1, 3 resimden 3.
    • Fully extend the bellows by lifting the #1 lever.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
    FixBot'a Sor
    Yorum Ekle
  2. Polaroid Automatic 100 Bellows Replacement: adım 2, 1 resimden 1.
    • Peel the two battery cable tabs off of the bellows.
    FixBot'a Sor
    Yorum Ekle
  3. Polaroid Automatic 100 Bellows Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
    • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
    • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Polaroid Automatic 100 Bellows Replacement: adım 4, 2 resimden 1. Polaroid Automatic 100 Bellows Replacement: adım 4, 2 resimden 2.
    • Open the back cover by pushing the lever on the bottom towards the left.
    FixBot'a Sor
    Yorum Ekle
  5. Polaroid Automatic 100 Bellows Replacement: adım 5, 1 resimden 1.
    • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
    • To make the screws easily accessible, close the bellows by pushing on the metal frame.
    • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
    FixBot'a Sor
    Yorum Ekle
  6. Polaroid Automatic 100 Bellows Replacement: adım 6, 1 resimden 1.
    • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
    FixBot'a Sor
    Yorum Ekle
  7. Polaroid Automatic 100 Bellows Replacement: adım 7, 2 resimden 1. Polaroid Automatic 100 Bellows Replacement: adım 7, 2 resimden 2.
    • Pull the bellow tabs back with long needle nose pliers.
    • Remove the bellows.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Katie Miller
680 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 2,736
