Ana içeriğe geç
Polaroid Automatic 100 Bottom Frame Spring Replacement
Neye ihtiyacın var
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: adım 1, 3 resimden 1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: adım 1, 3 resimden 2. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: adım 1, 3 resimden 3.
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: adım 2, 1 resimden 1.
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: adım 3, 1 resimden 1.
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: adım 4, 3 resimden 1. Polaroid Automatic 100 Bottom Frame Spring Replacement: adım 4, 3 resimden 2. Polaroid Automatic 100 Bottom Frame Spring Replacement: adım 4, 3 resimden 3.
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Katie Miller
680 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G3
4 Üyeler
11 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Yanıt Paylaş
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 1,577
