Ana içeriğe geç
Polaroid Cube Battery Replacement
Neye ihtiyacın var
    1. Polaroid Cube Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the SD card cover by twisting it using a Plastic Opening Tool
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid Cube Battery Replacement: adım 2, 1 resimden 1.
      • Use the Plastic Opening tool to pry off and remove the front cover.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid Cube Battery Replacement: adım 3, 1 resimden 1.
      • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
      FixBot'a Sor
      Yorum Ekle
    4. Polaroid Cube Battery Replacement: adım 4, 2 resimden 1. Polaroid Cube Battery Replacement: adım 4, 2 resimden 2.
      • Use the Plastic Opening Tool to pry open the shell of the camera.
      • There are four latches, one at each corner, that you will need to detach.
      FixBot'a Sor
      Yorum Ekle
    5. Polaroid Cube Battery Replacement: adım 5, 1 resimden 1.
      • Remove shell from top and bottom of camera.
      FixBot'a Sor
      Yorum Ekle
    6. Polaroid Cube Battery Replacement: adım 6, 1 resimden 1.
      • Remove the rubber seal wrapped around the camera.
      FixBot'a Sor
      Yorum Ekle
    7. Polaroid Cube Battery Replacement: adım 7, 2 resimden 1. Polaroid Cube Battery Replacement: adım 7, 2 resimden 2.
      • Remove the tape wrapped around the battery.
      FixBot'a Sor
      Yorum Ekle
    8. Polaroid Cube Battery Replacement: adım 8, 3 resimden 1. Polaroid Cube Battery Replacement: adım 8, 3 resimden 2. Polaroid Cube Battery Replacement: adım 8, 3 resimden 3.
      • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
      FixBot'a Sor
      Yorum Ekle
    9. Polaroid Cube Battery Replacement: adım 9, 2 resimden 1. Polaroid Cube Battery Replacement: adım 9, 2 resimden 2.
      • Use the plastic opening tool to remove the circuit board that the battery is connected to.
      FixBot'a Sor
      Yorum Ekle
    10. Polaroid Cube Battery Replacement: adım 10, 1 resimden 1.
      • Gently remove the battery pin connector from the circuit board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
heath lamkin
372 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G2
4 Üyeler
3 adet Kılavuz yazıldı
13Kılavuz Yorumları
Any idea where to find the replacement batteries?
hooverhogg - Yanıt Paylaş
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - Yanıt Paylaş
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor - Yanıt Paylaş
Was anyone able to to find the replacement batteries for the Cube?
yzorger - Yanıt Paylaş
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 62
Her zaman: 10,912
