Ana içeriğe geç
Polaroid Cube Lens Replacement
Neye ihtiyacın var
  1. Polaroid Cube Lens Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: adım 2, 1 resimden 1.
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: adım 3, 1 resimden 1.
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: adım 4, 2 resimden 1. Polaroid Cube Lens Replacement: adım 4, 2 resimden 2.
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: adım 5, 1 resimden 1.
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: adım 6, 1 resimden 1.
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: adım 7, 2 resimden 1. Polaroid Cube Lens Replacement: adım 7, 2 resimden 2.
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: adım 8, 3 resimden 1. Polaroid Cube Lens Replacement: adım 8, 3 resimden 2. Polaroid Cube Lens Replacement: adım 8, 3 resimden 3.
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: adım 9, 2 resimden 1. Polaroid Cube Lens Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: adım 10, 1 resimden 1.
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: adım 11, 2 resimden 1. Polaroid Cube Lens Replacement, Lens: adım 11, 2 resimden 2.
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: adım 12, 2 resimden 1. Polaroid Cube Lens Replacement: adım 12, 2 resimden 2.
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: adım 13, 1 resimden 1.
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Grant Baldwin
685 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G2
4 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - Yanıt
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 2,280
