Ana içeriğe geç
Polaroid Flash Unit Shell Replacement
Neye ihtiyacın var
  1. Polaroid Flash Unit Shell Replacement, Before you begin: adım 1, 1 resimden 1.
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Unplug all cables from your camera.
    FixBot'a Sor
    Yorum Ekle
  2. Polaroid Flash Unit Shell Replacement, Open your camera: adım 2, 2 resimden 1. Polaroid Flash Unit Shell Replacement, Open your camera: adım 2, 2 resimden 2.
    • Fully open the flash unit at the front of your camera.
    FixBot'a Sor
    Yorum Ekle
  3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: adım 3, 3 resimden 1. Polaroid Flash Unit Shell Replacement, Remove the screw cover: adım 3, 3 resimden 2. Polaroid Flash Unit Shell Replacement, Remove the screw cover: adım 3, 3 resimden 3.
    • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
    • Leave the pick inserted under the cover for the next step.
    FixBot'a Sor
    Yorum Ekle
  4. Polaroid Flash Unit Shell Replacement: adım 4, 3 resimden 1. Polaroid Flash Unit Shell Replacement: adım 4, 3 resimden 2. Polaroid Flash Unit Shell Replacement: adım 4, 3 resimden 3.
    • Slide the cover towards the flash to release the clips securing it.
    • Your pick might fall out—that's fine.
    • Pull the cover straight away from the camera and remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: adım 5, 3 resimden 1. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: adım 5, 3 resimden 2. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: adım 5, 3 resimden 3.
    • Hold the flash unit open with one hand.
    • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
    FixBot'a Sor
    Yorum Ekle
  6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: adım 6, 3 resimden 1. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: adım 6, 3 resimden 2. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: adım 6, 3 resimden 3.
    • Fully close the flash unit for a better grip on the shell.
    • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
    • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
    • You should feel and hear "clicks" as the clips release.
    • Pull the shell up and away from the camera to remove it.
    • During reassembly, put the shell in place and push down firmly to engage the clips.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Spencer Day
194.995 İtibar
1.243 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.593 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 386
