Ana içeriğe geç
Polaroid I-2 Film Door Replacement
Neye ihtiyacın var
  1. Polaroid I-2 Film Door Replacement, Safety information: adım 1, 3 resimden 1. Polaroid I-2 Film Door Replacement, Safety information: adım 1, 3 resimden 2. Polaroid I-2 Film Door Replacement, Safety information: adım 1, 3 resimden 3.
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 Film Door Replacement, Open the film door: adım 2, 2 resimden 1. Polaroid I-2 Film Door Replacement, Open the film door: adım 2, 2 resimden 2.
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 Film Door Replacement, Insert a blocker: adım 3, 3 resimden 1. Polaroid I-2 Film Door Replacement, Insert a blocker: adım 3, 3 resimden 2. Polaroid I-2 Film Door Replacement, Insert a blocker: adım 3, 3 resimden 3.
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 Film Door Replacement, Flip the camera over: adım 4, 3 resimden 1. Polaroid I-2 Film Door Replacement, Flip the camera over: adım 4, 3 resimden 2. Polaroid I-2 Film Door Replacement, Flip the camera over: adım 4, 3 resimden 3.
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 Film Door Replacement, Unfasten the bottom cover: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 Film Door Replacement, Unclip the bottom cover: adım 6, 3 resimden 1. Polaroid I-2 Film Door Replacement, Unclip the bottom cover: adım 6, 3 resimden 2. Polaroid I-2 Film Door Replacement, Unclip the bottom cover: adım 6, 3 resimden 3.
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 Film Door Replacement: adım 7, 3 resimden 1. Polaroid I-2 Film Door Replacement: adım 7, 3 resimden 2. Polaroid I-2 Film Door Replacement: adım 7, 3 resimden 3.
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 Film Door Replacement: adım 8, 3 resimden 1. Polaroid I-2 Film Door Replacement: adım 8, 3 resimden 2. Polaroid I-2 Film Door Replacement: adım 8, 3 resimden 3.
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 Film Door Replacement: adım 9, 3 resimden 1. Polaroid I-2 Film Door Replacement: adım 9, 3 resimden 2. Polaroid I-2 Film Door Replacement: adım 9, 3 resimden 3.
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 Film Door Replacement, Remove the bottom cover: adım 10, 3 resimden 1. Polaroid I-2 Film Door Replacement, Remove the bottom cover: adım 10, 3 resimden 2. Polaroid I-2 Film Door Replacement, Remove the bottom cover: adım 10, 3 resimden 3.
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
  11. Polaroid I-2 Film Door Replacement, Disconnect the film door: adım 11, 3 resimden 1. Polaroid I-2 Film Door Replacement, Disconnect the film door: adım 11, 3 resimden 2. Polaroid I-2 Film Door Replacement, Disconnect the film door: adım 11, 3 resimden 3.
    • Insert the flat end of a spudger between the film door's left hinge and the frame.
    • Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
    • Pull the film door towards the front of the camera to completely disconnect its left hinge.
  12. Polaroid I-2 Film Door Replacement: adım 12, 3 resimden 1. Polaroid I-2 Film Door Replacement: adım 12, 3 resimden 2. Polaroid I-2 Film Door Replacement: adım 12, 3 resimden 3.
    • Tilt the left edge of the film door up to separate the left hinge's rubber grommet.
    • Remove the film door.
    • At this point, you can remove the cloth blocker from under the print roller.
    • During reassembly, hook the left hinge on its post and push the right hinge over its post until it snaps into place.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
127.654 İtibar
592 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.893 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 306
