Ana içeriğe geç
Polaroid I-2 Top Cover Replacement
Neye ihtiyacın var
  1. Polaroid I-2 Top Cover Replacement, Safety information: adım 1, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Safety information: adım 1, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Safety information: adım 1, 3 resimden 3.
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 Top Cover Replacement, Open the film door: adım 2, 2 resimden 1. Polaroid I-2 Top Cover Replacement, Open the film door: adım 2, 2 resimden 2.
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 Top Cover Replacement, Insert a blocker: adım 3, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Insert a blocker: adım 3, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Insert a blocker: adım 3, 3 resimden 3.
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 Top Cover Replacement, Flip the camera over: adım 4, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Flip the camera over: adım 4, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Flip the camera over: adım 4, 3 resimden 3.
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 Top Cover Replacement, Unfasten the bottom cover: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 Top Cover Replacement, Unclip the bottom cover: adım 6, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Unclip the bottom cover: adım 6, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Unclip the bottom cover: adım 6, 3 resimden 3.
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 Top Cover Replacement: adım 7, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 7, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 7, 3 resimden 3.
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 Top Cover Replacement: adım 8, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 8, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 8, 3 resimden 3.
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 Top Cover Replacement: adım 9, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 9, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 9, 3 resimden 3.
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 Top Cover Replacement, Remove the bottom cover: adım 10, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Remove the bottom cover: adım 10, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Remove the bottom cover: adım 10, 3 resimden 3.
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
  11. Polaroid I-2 Top Cover Replacement, Remove the blocker: adım 11, 1 resimden 1.
    • At this point, you can remove the blocker from the film compartment.
  12. Polaroid I-2 Top Cover Replacement, Unfasten the back cover: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the back cover.
  13. Polaroid I-2 Top Cover Replacement, Separate the alignment pegs: adım 13, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Separate the alignment pegs: adım 13, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Separate the alignment pegs: adım 13, 3 resimden 3.
    • There are two alignment pegs along the bottom edge of the back cover.
    • Insert a spudger between the frame and the alignment hole on the back cover.
    • Twist the spudger to lift the back cover off of the alignment peg.
    • Repeat for the second alignment peg.
  14. Polaroid I-2 Top Cover Replacement, Disassembly information: adım 14, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Disassembly information: adım 14, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Disassembly information: adım 14, 3 resimden 3.
    • There are eight large clips that secure the back cover. The next four steps show how to release them.
    • These clips are very strong and require significant force to release.
    • The procedure to release the clips is tricky and will require time and patience to perform correctly.
  15. Polaroid I-2 Top Cover Replacement, Unclip the back cover: adım 15, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Unclip the back cover: adım 15, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Unclip the back cover: adım 15, 3 resimden 3.
    • Releasing the clips requires getting a tool between the covered "thin" edge of the front cover and the clips themselves.
    • Angle an opening pick upward and insert it at the gap where the bottom right corner of the back cover meets the triangular tip of the front cover’s right edge.
    • Push the pick up to get it above the overhanging lip in the back cover.
    • You'll see the plastic warp a little. This is normal.
    • While pushing upward, slowly rotate the pick towards the left edge of the camera until it's under the front cover.
    • The pick can slip out easily, so this may take a few tries.
  16. Polaroid I-2 Top Cover Replacement: adım 16, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 16, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 16, 3 resimden 3.
    • While pushing the pick downward, slide it all the way up the right edge to release the clips.
    • Keep the pick as upright as possible while sliding to avoid hitting the clips.
    • The plastic in the lip of the back cover will warp. This is normal.
    • Leave the pick at the top corner before continuing to prevent the clips from resecuring.
  17. Polaroid I-2 Top Cover Replacement: adım 17, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 17, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 17, 3 resimden 3.
    • Angle a second opening pick upward and insert it at the gap where the bottom left corner of the back cover meets the triangular tip of the front cover’s left edge.
    • While pushing upward, slowly rotate the pick towards the right edge of the camera until it's under the front cover.
  18. Polaroid I-2 Top Cover Replacement: adım 18, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 18, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 18, 3 resimden 3.
    • While pushing the pick downward, slide it all the way up the left edge to release the remaining clips.
  19. Polaroid I-2 Top Cover Replacement, Reposition the back cover: adım 19, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Reposition the back cover: adım 19, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Reposition the back cover: adım 19, 3 resimden 3.
    • Don't try to pull the back cover off just yet, as it's still connected by a cable.
    • At this point, the back cover should feel loose. If any parts still feel connected, repeat the last four steps until all the clips release.
    • Pull the back cover off the camera and rotate it over the right edge to expose the flex cable.
    • During reassembly, make sure the the flex cable isn't caught between the covers before re-engaging the clips.
  20. Polaroid I-2 Top Cover Replacement, Remove the tape: adım 20, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Remove the tape: adım 20, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Remove the tape: adım 20, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to peel off the tape covering the interconnect cable ZIF connector on the control board.
    • Set the tape aside. You'll reuse it during reassembly.
  21. Polaroid I-2 Top Cover Replacement, Disconnect the control board: adım 21, 2 resimden 1. Polaroid I-2 Top Cover Replacement, Disconnect the control board: adım 21, 2 resimden 2.
    • Use the flat end of a spudger to lift up the locking flap on the control board ZIF connector.
  22. Polaroid I-2 Top Cover Replacement: adım 22, 3 resimden 1. Polaroid I-2 Top Cover Replacement: adım 22, 3 resimden 2. Polaroid I-2 Top Cover Replacement: adım 22, 3 resimden 3.
    • Use tweezers to pull the interconnect cable out of its slot in the control board.
  23. Polaroid I-2 Top Cover Replacement, Unfasten the top cover: adım 23, 3 resimden 1. Polaroid I-2 Top Cover Replacement, Unfasten the top cover: adım 23, 3 resimden 2. Polaroid I-2 Top Cover Replacement, Unfasten the top cover: adım 23, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws securing the top cover.
  24. Polaroid I-2 Top Cover Replacement, Unclip the top cover: adım 24, 2 resimden 1. Polaroid I-2 Top Cover Replacement, Unclip the top cover: adım 24, 2 resimden 2.
    • The next six steps demonstrate how to release the top cover's clips. These clips can re-engage easily, so you may need to repeat certain steps to release all of the clips.
    • Angle an opening pick upward and insert in the gap at the top right corner of the top cover and front cover, next to the flash.
  25. Polaroid I-2 Top Cover Replacement: adım 25, 2 resimden 1. Polaroid I-2 Top Cover Replacement: adım 25, 2 resimden 2.
    • Leave the pick in the gap before continuing to prevent the clips from re‑engaging.
  26. Polaroid I-2 Top Cover Replacement: adım 26, 2 resimden 1. Polaroid I-2 Top Cover Replacement: adım 26, 2 resimden 2.
    • Angle a second opening pick upward and insert in the gap at the top left corner of the top cover and front cover.
  27. Polaroid I-2 Top Cover Replacement: adım 27, 2 resimden 1. Polaroid I-2 Top Cover Replacement: adım 27, 2 resimden 2.
    • Leave the pick in the gap before continuing to prevent the clips from re-engaging.
  28. Polaroid I-2 Top Cover Replacement: adım 28, 2 resimden 1. Polaroid I-2 Top Cover Replacement: adım 28, 2 resimden 2.
    • Insert the flat end of a spudger between the frame and the top cover's left external clip, above the viewfinder.
    • Twist the spudger to release the clip.
    • If one of the opening picks fall out, don't worry! Continue with the guide as normal.
  29. Polaroid I-2 Top Cover Replacement: adım 29, 2 resimden 1. Polaroid I-2 Top Cover Replacement: adım 29, 2 resimden 2.
    • Insert the tip of an opening pick between the frame and the top cover's right external clip.
    • Pry up to release the clip.
  30. Polaroid I-2 Top Cover Replacement, Remove the lens cap: adım 30, 1 resimden 1.
    • Pull the lens cap off and remove it.
  31. Polaroid I-2 Top Cover Replacement, Remove the top cover: adım 31, 2 resimden 1. Polaroid I-2 Top Cover Replacement, Remove the top cover: adım 31, 2 resimden 2.
    • Lift the top cover off the camera and remove it.
    • During reassembly, push the top cover onto the frame until the clips re-engage.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
125.004 İtibar
582 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 142
