Giriş
Use this guide to replace the selectable inner lens in your Polaroid Now+ (Gen 3) instant camera.
You can also use this guide to clean the selectable lens.
Neye ihtiyacın var
If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
Unplug and fully power down your camera.
Put on the lens cap to avoid scratching your lens during disassembly.
Hold down the latch on the left side of the camera and open the film door.
Bu adımda kullanılan alet:Magnetic Project Mat$16.96
Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
Insert the flat edge of an opening pick in the seam between the front and rear shells, just above the USB‑C port on the right edge.
Use your pick to pry the rear shell away from the front shell.
Gently pull the rear shell off the main body of the camera.
Press the shell firmly onto the main body so all the clips engage.
Check around the shell seam and make sure there are no gaps. If there are, firmly press the shells together to engage the clip near the gap.
To minimize risk, avoid touching the boards, wires, and other exposed components with your fingers or metal tools. Consider wearing rubber gloves if working near the board.
Use your fingers to remove the piece of tape securing the battery and its cables (just below the viewfinder).
Use a spudger to flip up the hinged locking flap on the sub board ZIF connector.
Use a pair of tweezers or your fingers to gently pull the cable straight out of its socket.
Firmly grip the larger end of the plastic battery connector with one hand and the battery's cable in the other—grip the battery cable as close to the connector as possible.
Pull the battery cable straight away from the connector to disconnect it.
Remove the battery.
Use a Phillips screwdriver to remove the two 3 mm‑long film door hinge screws (one on either side of the camera).
Use the flat end of a spudger to push one of the film door hinges away from the camera and off its post.
Repeat the process to detach the other hinge.
Lift the film door and remove it.
Make sure there are grommets installed in the film door hinges. To install them, press the grommets into the film door hinges, with the wide end facing in.
Hook one of the hinges on its post and then push the other one into place until it snaps over its post.
Flip the camera over and position it so the lens is facing away from you.
Bu adımda kullanılan alet:Phillips #00 Screwdriver$5.49
Use a Phillips screwdriver to remove the three screws securing the front shell:
Two 5.9 mm‑long screws hidden in recesses on the left and right sides (one near the battery recess and one with a cutout in the main board)
One 5.4 mm‑long screw on the top edge of the main board
With the right side of the camera facing up, hold the main body of your camera in one hand and the front shell in the other.
Gently squeeze the sides of the front shell to release the clips and pull the shell off the main body of the camera.
Remove the metal film‑door lever and the larger white gear on the right side of the camera and put them aside—you'll need them for reassembly.
Use a spudger to lift the hinged locking‑flap on the light sensor cable ZIF connector (the cable is attached to the outer lens).
Use a pair of tweezers to gently pull the cable straight out of its socket.
The outer lens has three clips—one on the top, one on the left, and one on the bottom.
Use your finger to lift the top clip and pull it towards the front of the camera until it detaches.
Remove the outer lens.
With the cable on the bottom edge, press the outer lens over the inner lens until it clicks into place.
Use the two tabs along the top edge to make sure the lens is properly aligned.
Make sure the larger cutout on the cable goes over its alignment post.
Gently pull the selectable lens straight away from the camera to remove it.
A larger post that goes near the center of the lens.
A smaller post that goes into the track cutout.
