Ana içeriğe geç
Polaroid Now Gen 3 Film Shield Replacement
Neye ihtiyacın var
  1. Polaroid Now Gen 3 Film Shield Replacement, Safety precautions: adım 1, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Safety precautions: adım 1, 2 resimden 2.
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Before you begin:
    • Unplug and fully power down your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid Now Gen 3 Film Shield Replacement, Open the film door: adım 2, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Open the film door: adım 2, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Open the film door: adım 2, 3 resimden 3.
    • Throughout this guide, directional words (front, back, left, right) are from the perspective of using the camera—or when the lens faces away from you.
    • Hold down the latch on the left side of the camera and open the film door.
  3. Polaroid Now Gen 3 Film Shield Replacement, Remove the rear shell screw: adım 3, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the rear shell screw: adım 3, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Remove the rear shell screw: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $16.96
    • Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
    • The screw is hidden inside the camera on the back edge—you may need to use a flashlight to see it, as well as a skinny, long‑shank screwdriver to reach it.
    • Be careful when removing your screwdriver, as the screw can easily fall inside the camera. If it does, hold the camera above your work surface and gently shake it so the screw falls out.
  4. Polaroid Now Gen 3 Film Shield Replacement, Release the rear shell clips: adım 4, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Release the rear shell clips: adım 4, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Release the rear shell clips: adım 4, 3 resimden 3.
    • Insert the flat edge of an opening pick in the seam between the front and rear shells, just above the USB‑C port on the right edge.
    • Use your pick to pry the rear shell away from the front shell.
    • Keep the inserted edge of the pick pointed toward the rear shell when separating it. This helps release the tight plastic clips holding them together.
  5. Polaroid Now Gen 3 Film Shield Replacement: adım 5, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement: adım 5, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement: adım 5, 3 resimden 3.
    • You should feel and hear distinct "clicks" as the clips release. If you don't, try again—it may take multiple attempts.
    • Slide your pick around the top right corner and along the top edge to release the clips.
  6. Polaroid Now Gen 3 Film Shield Replacement: adım 6, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement: adım 6, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement: adım 6, 3 resimden 3.
    • Continue sliding your pick along the top edge, around the top left corner, and down the left edge to release the clips. Stop when you get to the film door latch.
  7. Polaroid Now Gen 3 Film Shield Replacement: adım 7, 1 resimden 1.
    • Gently flip the camera over, making sure none of the clips re‑engage.
  8. Polaroid Now Gen 3 Film Shield Replacement: adım 8, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement: adım 8, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement: adım 8, 3 resimden 3.
    • Remember to keep the inserted edge of the pick pointed towards the rear shell.
    • Insert your opening pick in the seam near the USB‑C port and slide it around the corner and along the bottom edge to release the remaining clips.
  9. Polaroid Now Gen 3 Film Shield Replacement, Camera mirror warning: adım 9, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Camera mirror warning: adım 9, 2 resimden 2.
    • Removing the rear shell in the next step exposes the camera mirror. Be careful not to smudge it or get any debris on it. If you accidentally do, use a lint‑free cloth to gently wipe the mirror clean.
  10. Polaroid Now Gen 3 Film Shield Replacement, Remove the rear shell: adım 10, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the rear shell: adım 10, 2 resimden 2.
    • Gently pull the rear shell off the main body of the camera.
    • The shell should slide off easily. If it doesn't, check to see if any clips re‑engaged and use your opening pick to release them.
    • During reassembly:
    • Press the shell firmly onto the main body so all the clips engage.
    • You should feel and hear distinct "clicks" as the clips engage.
    • Check around the shell seam and make sure there are no gaps. If there are, firmly press the shells together to engage the clip near the gap.
  11. Polaroid Now Gen 3 Film Shield Replacement, Capacitor warning: adım 11, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Capacitor warning: adım 11, 2 resimden 2.
    • The capacitor in your camera holds an electrical charge and can deliver a potentially dangerous electric shock if you touch the boards incorrectly.
    • To minimize risk, avoid touching the boards, wires, and other exposed components with your fingers or metal tools. Consider wearing rubber gloves if working near the board.
  12. Polaroid Now Gen 3 Film Shield Replacement, Flip your camera over: adım 12, 1 resimden 1.
    • Flip your camera over so the bottom is facing up.
  13. Polaroid Now Gen 3 Film Shield Replacement, Remove the film door screws: adım 13, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the film door screws: adım 13, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 3 mm‑long film door hinge screws (one on either side of the camera).
  14. Polaroid Now Gen 3 Film Shield Replacement, Insert a clean cloth: adım 14, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Insert a clean cloth: adım 14, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Insert a clean cloth: adım 14, 3 resimden 3.
    • Open the film door and place a clean cloth in the compartment.
    • This prevents the door from re‑securing while detaching the hinges.
  15. Polaroid Now Gen 3 Film Shield Replacement, Detach the film door: adım 15, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Detach the film door: adım 15, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Detach the film door: adım 15, 3 resimden 3.
    • The small, plastic grommets inside the film door hinges can easily fall off during this step. Don't lose them—you'll need them for reassembly.
    • Use the flat end of a spudger to push one of the film door hinges away from the camera and off its post.
    • Repeat the process to detach the other hinge.
    • Hold the film door steady so the already detached hinge doesn't slide back into place.
  16. Polaroid Now Gen 3 Film Shield Replacement: adım 16, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement: adım 16, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement: adım 16, 3 resimden 3.
    • Check to see if either of the small, plastic hinge grommets stayed on their posts.
    • If they did, remove them and set them aside.
  17. Polaroid Now Gen 3 Film Shield Replacement, Remove the film door: adım 17, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the film door: adım 17, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Remove the film door: adım 17, 3 resimden 3.
    • Lift the film door and remove it.
    • At this point, you can remove the cloth from the film door compartment.
    • Make sure there are grommets installed in the film door hinges. To install them, press the grommets into the film door hinges, with the wide end facing in.
    • Hook one of the hinges on its post and then push the other one into place until it snaps over its post.
  18. Polaroid Now Gen 3 Film Shield Replacement, Remove the print roller screw: adım 18, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the print roller screw: adım 18, 2 resimden 2.
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips screwdriver to remove the 3.9 mm‑long screw securing the print roller.
    • You may need to use a flashlight to see the screw, as well as a skinny, long‑shank screwdriver to reach it.
  19. Polaroid Now Gen 3 Film Shield Replacement, Unclip the print roller: adım 19, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Unclip the print roller: adım 19, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Unclip the print roller: adım 19, 3 resimden 3.
    • Two plastic tabs secure the center of the print roller.
    • Use the tip of a spudger to depress both plastic tabs until their hooks release from the print roller—you'll hear an audible "click."
  20. Polaroid Now Gen 3 Film Shield Replacement, Remove the print roller: adım 20, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the print roller: adım 20, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Remove the print roller: adım 20, 3 resimden 3.
    • Grab the print roller by one of its arms and pull it straight out of its plastic housing.
    • Pull straight away from the housing to avoid bending or warping the metal.
    • If you're having trouble, make sure the clips are released. You may have to hold the clips down while pulling.
  21. Polaroid Now Gen 3 Film Shield Replacement: adım 21, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement: adım 21, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement: adım 21, 3 resimden 3.
    • The print roller is a sensitive component. Be extremely careful during reassembly to not bend or warp the metal.
    • During reassembly, note the following to properly reinsert the print roller into its plastic housing:
    • Two metal L-shaped rails at the bottom of the print roller need to slide under cutouts in the plastic housing.
    • Two metal hooks at the top of the print roller need to fit under the top corners of the plastic housing.
    • Insert the print roller at a downward angle to fit the hooks in first before sliding the rails into place.
    • Push the print roller into its plastic housing until you hear the plastic tabs click back into place.
  22. Polaroid Now Gen 3 Film Shield Replacement, Unclip the film shield tray: adım 22, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Unclip the film shield tray: adım 22, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Unclip the film shield tray: adım 22, 3 resimden 3.
    • Two clips secure the center of the film shield tray.
    • Insert the tip of an opening pick between one of the outer edges of the film shield tray and the plastic housing.
    • Slide your opening pick along the film shield tray to release the clips—you should feel and hear distinct "clicks" as the clips release.
  23. Polaroid Now Gen 3 Film Shield Replacement, Remove the film shield tray: adım 23, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the film shield tray: adım 23, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Remove the film shield tray: adım 23, 3 resimden 3.
    • Pull the film shield tray out of its recess and remove it.
    • To avoid damaging the film shield, first insert the long edge with an angle into the recess before pushing the tray into place. The side with cutouts should be facing up.
    • Push the film shield tray into place until you feel and hear the clips click into place.
  24. Polaroid Now Gen 3 Film Shield Replacement, Unhook the film shield: adım 24, 3 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Unhook the film shield: adım 24, 3 resimden 2. Polaroid Now Gen 3 Film Shield Replacement, Unhook the film shield: adım 24, 3 resimden 3.
    • The film shield sits on four alignment pegs.
    • Use the point of a spudger or tweezers to carefully lift the shield off its pegs.
    • During reassembly, align the film shield over its pegs and a use spudger to gently press it into place.
  25. Polaroid Now Gen 3 Film Shield Replacement, Remove the film shield: adım 25, 2 resimden 1. Polaroid Now Gen 3 Film Shield Replacement, Remove the film shield: adım 25, 2 resimden 2.
    • Pull the film shield out of its slot in the plastic housing and remove it.
    • During reassembly, insert the film shield into its slot so the flat section with cutouts is on top.
Sonuç
Spencer Day
148.852 İtibar
995 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.583 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 153
