Ana içeriğe geç
Polaroid OneStep 2 Flash Cover Replacement
Neye ihtiyacın var
    1. Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: adım 1, 3 resimden 1. Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: adım 1, 3 resimden 2. Polaroid OneStep 2 Flash Cover Replacement, Flash Cover: adım 1, 3 resimden 3.
      • Unscrew the four 5mm screws on the base of the camera. Remove the two pieces of the base.
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid OneStep 2 Flash Cover Replacement: adım 2, 3 resimden 1. Polaroid OneStep 2 Flash Cover Replacement: adım 2, 3 resimden 2. Polaroid OneStep 2 Flash Cover Replacement: adım 2, 3 resimden 3.
      • Unscrew the four 5mm screws on the top of the inside base piece.
      • Unscrew the two 5mm screws on the bottom of the inside base piece which is near the strap.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid OneStep 2 Flash Cover Replacement: adım 3, 1 resimden 1.
      • Remove the inside black base piece.
      FixBot'a Sor
      Yorum Ekle
    4. Polaroid OneStep 2 Flash Cover Replacement: adım 4, 2 resimden 1. Polaroid OneStep 2 Flash Cover Replacement: adım 4, 2 resimden 2.
      • With force separate the front white piece from the back of the camera. You will use your hands to pull it apart.
      FixBot'a Sor
      Yorum Ekle
    5. Polaroid OneStep 2 Flash Cover Replacement: adım 5, 2 resimden 1. Polaroid OneStep 2 Flash Cover Replacement: adım 5, 2 resimden 2.
      • Forcefully pull on the flash cover until it is removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Abby Boucher
829 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 2,040
