Ana içeriğe geç
Polaroid OneStep 2 Lens Replacement
Neye ihtiyacın var
  1. Polaroid OneStep 2 Lens Replacement, Lens: adım 1, 3 resimden 1. Polaroid OneStep 2 Lens Replacement, Lens: adım 1, 3 resimden 2. Polaroid OneStep 2 Lens Replacement, Lens: adım 1, 3 resimden 3.
    • Unscrew the four Phillips #0 5 mm screws on the base of the camera.
    • Remove the two pieces of the base.
  2. Polaroid OneStep 2 Lens Replacement: adım 2, 3 resimden 1. Polaroid OneStep 2 Lens Replacement: adım 2, 3 resimden 2. Polaroid OneStep 2 Lens Replacement: adım 2, 3 resimden 3.
    • Remove the four Phillips #0 5mm screws on the top of the inside base piece.
    • Remove the Phillips #0 5mm two screws on the bottom of the inside base piece nearer the strap.
  3. Polaroid OneStep 2 Lens Replacement: adım 3, 1 resimden 1.
    • Remove the black inside base piece.
  4. Polaroid OneStep 2 Lens Replacement: adım 4, 2 resimden 1. Polaroid OneStep 2 Lens Replacement: adım 4, 2 resimden 2.
    • With force separate the white front piece from the back of the camera. You will use your hands and pull it apart.
  5. Polaroid OneStep 2 Lens Replacement: adım 5, 3 resimden 1. Polaroid OneStep 2 Lens Replacement: adım 5, 3 resimden 2. Polaroid OneStep 2 Lens Replacement: adım 5, 3 resimden 3.
    • Remove the two Phillips #0 3mm screws on the black ring holding the lens in place and remove the ring.
  6. Polaroid OneStep 2 Lens Replacement: adım 6, 2 resimden 1. Polaroid OneStep 2 Lens Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the clear plastic lens with tweezers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Abby Boucher
829 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
I followed this guide to a T, but it stops right before the replacement. I can even see the cracked lense in the last photo beneath the plastic lense you removed. How would one remove that internal lense and replace it?
JAD - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 8,352
