Ana içeriğe geç
Polaroid Onestep Close Up Primary Lens Replacement
Neye ihtiyacın var
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: adım 1, 3 resimden 1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: adım 1, 3 resimden 2. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: adım 1, 3 resimden 3.
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: adım 2, 2 resimden 1. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: adım 2, 2 resimden 2.
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: adım 3, 3 resimden 1. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: adım 3, 3 resimden 2. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: adım 3, 3 resimden 3.
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: adım 4, 1 resimden 1.
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: adım 5, 2 resimden 1. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: adım 5, 2 resimden 2.
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Christopher Collazo
318 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 18
Her zaman: 1,430
