Ana içeriğe geç
Polaroid Onestep Close Up Shutter Switch Replacement
Neye ihtiyacın var
    1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: adım 1, 3 resimden 1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: adım 1, 3 resimden 2. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: adım 1, 3 resimden 3.
      • Begin by opening the top of the camera (flash assembly) to a slight angle.
      • Next, angle the flash assembly slightly upward and pry off the connections carefully.
      • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: adım 2, 2 resimden 1. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: adım 2, 2 resimden 2.
      • Slide the action button, on the bottom of the camera, to open the bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: adım 3, 3 resimden 1. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: adım 3, 3 resimden 2. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: adım 3, 3 resimden 3.
      • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
      • Pull off the face plate.
      FixBot'a Sor
      Yorum Ekle
    1. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: adım 4, 3 resimden 1. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: adım 4, 3 resimden 2. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: adım 4, 3 resimden 3.
      • After the face plate is off, the shutter switch should slide out easily.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyler OBrien
627 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G5
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
where did you get the replacement parts for this?
Jacob Sokolove - Yanıt Paylaş
I’d love to find a new shutter piece..
Joni Korkkula - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 5,008
