Ana içeriğe geç
Polaroid P902 Motherboard Replacement
Neye ihtiyacın var
  1. Polaroid P902 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. Polaroid P902 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
    FixBot'a Sor
    Yorum Ekle
  3. Polaroid P902 Motherboard Replacement: adım 3, 2 resimden 1. Polaroid P902 Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
    FixBot'a Sor
    Yorum Ekle
  4. Polaroid P902 Motherboard Replacement: adım 4, 1 resimden 1.
    • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
    FixBot'a Sor
    Yorum Ekle
  5. Polaroid P902 Motherboard Replacement: adım 5, 3 resimden 1. Polaroid P902 Motherboard Replacement: adım 5, 3 resimden 2. Polaroid P902 Motherboard Replacement: adım 5, 3 resimden 3.
    • Using a soldering iron, desolder the points circled on the picture until the solder have liquefied enough to be able to remove the wires from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  6. Polaroid P902 Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently lift the circuit board from the housing. You have now successfully removed the circuit board. Now, you can insert the new board to the tablet.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mina Tobeck
133 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Spring 2018 IUPUI, Team S2-G2, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S2G2
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 899
