Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The motherboard is one of the most important parts of the device, containing the microprocessor chip and connects everything together. Other components of the device can also be included in the motherboard to enhance the performance. This is the heart and brains of a device and needs to be handled with care.
Neye ihtiyacın var
Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
