Ana içeriğe geç
Polaroid PMID4312 Battery Replacement
Neye ihtiyacın var
    1. Polaroid PMID4312 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid PMID4312 Battery Replacement: adım 2, 1 resimden 1.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid PMID4312 Battery Replacement: adım 3, 1 resimden 1.
      • The device is now free from the plastic case.
      FixBot'a Sor
      Yorum Ekle
    4. Polaroid PMID4312 Battery Replacement: adım 4, 2 resimden 1. Polaroid PMID4312 Battery Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
      FixBot'a Sor
      Yorum Ekle
    5. Polaroid PMID4312 Battery Replacement: adım 5, 1 resimden 1.
      • Peel back any yellow tape not directly attached to the battery.
      • Using a soldering iron, desolder the two wires that connect the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Christopher Bertan
479 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Lacy Fall 2016 USF Tampa, Team 5-4, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G4
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 902
