Ana içeriğe geç
Polaroid PMID4312 Motherboard Replacement
Neye ihtiyacın var
  1. Polaroid PMID4312 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
  2. Polaroid PMID4312 Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
  3. Polaroid PMID4312 Motherboard Replacement: adım 3, 1 resimden 1.
    • The device is now free from the plastic case.
  4. Polaroid PMID4312 Motherboard Replacement: adım 4, 2 resimden 1. Polaroid PMID4312 Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
  5. Polaroid PMID4312 Motherboard Replacement: adım 5, 1 resimden 1.
    • Peel back any yellow tape not directly attached to the battery.
    • Using a soldering iron, desolder the two wires that connect the battery to the motherboard.
  6. Polaroid PMID4312 Motherboard Replacement, Speaker: adım 6, 2 resimden 1. Polaroid PMID4312 Motherboard Replacement, Speaker: adım 6, 2 resimden 2.
    • Remove the two 5mm screws attached to the top right and bottom left corners of the speaker
  7. Polaroid PMID4312 Motherboard Replacement: adım 7, 2 resimden 1. Polaroid PMID4312 Motherboard Replacement: adım 7, 2 resimden 2.
    • Solder off the wires connecting the speaker to the device
  8. Polaroid PMID4312 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull the speaker out of the casing to release it.
  9. Polaroid PMID4312 Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Polaroid PMID4312 Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Using the ph#00 screwdriver, remove the four 5mm screws connecting the motherboard to the casing.
  10. Polaroid PMID4312 Motherboard Replacement: adım 10, 3 resimden 1. Polaroid PMID4312 Motherboard Replacement: adım 10, 3 resimden 2. Polaroid PMID4312 Motherboard Replacement: adım 10, 3 resimden 3.
    • Using a spudger or a fingernail, detach the two ribbons from the motherboard by pushing the plastic tab away from the Zero Insertion Force connectors.
    • As the name implies, no force is needed to plug in or remove the cable.
    • Be sure you are prying the plastic tabs connected tab and not the connector itself.
  11. Polaroid PMID4312 Motherboard Replacement: adım 11, 1 resimden 1.
    • Now carefully remove the motherboard.
Sonuç
Christopher Bertan
479 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Lacy Fall 2016 USF Tampa, Team 5-4, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 193
