Ana içeriğe geç
Polaroid PTAB7XC Power Button Replacement
Neye ihtiyacın var
  1. Polaroid PTAB7XC Power Button Replacement, Power Button: adım 1, 2 resimden 1. Polaroid PTAB7XC Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver by turning them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Power Button Replacement: adım 2, 2 resimden 1. Polaroid PTAB7XC Power Button Replacement: adım 2, 2 resimden 2.
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • The plastic case is now free from the device.
    • The plastic power button may or may not fall out at this point. There is no problem if it does.
  3. Polaroid PTAB7XC Power Button Replacement: adım 3, 1 resimden 1.
    • Use tweezers to push on the side of the black plastic power button that is outside of the device case until the button is as far in as possible.
    • Pull on the part of the broken power button that is exposed on the inside of the device case using tweezers until the button itself comes loose of the case.
    • The power button is now replaceable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 909
